lord_estacado
Newbie level 1
cdb2oa
Hi, I'm trying to translate the cdb libraries to oa. I've followed this instructions (**broken link removed**) but I get a lot of warnings and errors:
WARNING (CDBOA-406): Directory <path>/<name> is in a cellview. The directory
and its contents will be copied to the destination database
but will not be translated.
WARNING (CDBOA-413): The OpenAccess cds.lib definition for library "name"
points to CDBA data. The translator will fail if the
library you are translating attempts to reference CDBA data
from OpenAccess. Remove the definition from the OpenAccess
cds.lib file or redefine it so that it points to OpenAccess
data.
WARNING (CDBOA-502): Cannot find technology information for library
<path>/<name>. Translating the library without technology
information.
Generated once. The translator is unable to find any
technology information for the library. There is no
technology library attached and no valid technology file
(tech.db) in the OpenAccess library directory.
Fix the technology references in the CDBA version and run
the translator again or attach appropriate technology
information in the OpenAccess version of the library.
ERROR (CDBOA-612): {Cell | View} <path>/<name> has an illegal CDBA name. Its
contents will be copied to the OpenAccess version of the
library but will not be translated.
Generated 2 times. The translator does not convert cells
or cellviews that have illegal CDBA names. The contents are
copied to the OpenAccess version of the library but are not
translated. This could mean that you end up with CDBA data
in the OpenAccess version of your library. Check the cell
or cellview in question and, if it is required, ensure that
it has a legal CDBA name and then run the translator again.
Can anyone help me, please? Thanks!
data.
information.
