Probably you have not selected the device in Extreme Burner Software. I am using the same and it works fine.
Make sure that MISO, MOSI, SCK connections are proper.
i think VCC pin is missing in your jtag
ok then you should check this its seem you having ISP jtag
PIN 2 is VCC for ISP
Maybe your problem is software related.
Try to use http://avr8-burn-o-mat.aaabbb.de/avr8_burn_o_mat_avrdude_gui_en.html and see if this changes anything.
I've been using the application for a very long time with USBasp without any problem.
I didn't find any info in the previous post about the programmer hardware you are using, which one is it?
