Problem : Picbasic Pro and TMR0.
Jum
Junior Member level 2
I would like to know like I can assign value to TMR0 using the picbasic. Se puede asignar usando TMR0=200?.
' Define puertos A y B.
TRISA =%00000000 ' Todas las lineas como entrada.
TRISB =%00001100 ' Todas las lineas como salida.
TRISC =%00000000
' Define variables del sistema
dato VAR WORD
conta VAR BYTE
' Comienza programa.
PORTA=0
PORTB=0
PORTC=1
'Set TMR0 to interrupt every 16.384 milliseconds
tmr0 = 61
OPTION_REG = %01010111 ' Set TMR0 configuration and enable PORTB pullups
INTCON = $a0 ' Enable TMR0 interrupts
ON Interrupt GoTo timerint
inicio:
GoTo inicio
Disable
timerint:
conta = conta + 1
IF conta = 20 Then
conta = 0
Toggle PORTB.3
tmr0 = 61
EndIF
Resume
Enable
End
This program doesn't work. If I modify the you line that they put TMR0=61 and I eliminate them it works correctly. Does somebody know that it happens?
jum_spain@hotmail.com
