problem of running IC5141 in Suse 9.3
lcking
Member level 1
Member level 1
cadence ipc:0 timeout icfb
I have installed IC5141 in Suse9.3, but there are some problems in running IC5141. The startup speed of IC5141 is very slow. and when I click the menu "library manager...", IC5141 hangs.
This is the log of CDS.
\o
\o COPYRIGHT ?1992-2004 CADENCE DESIGN SYSTEMS INC. ALL RIGHTS RESERVED.
\o ?1992-2004 UNIX SYSTEMS Laboratories INC.,
\o Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\p >
\o 8-bit PseudoColor Visual is not available (default Visual option).
\o Using 24-bit TrueColor Visual.
\o The program xdpyinfo can be used to verify the Visuals available
\o for your display.
\o Loading PRshare.cxt
\o Loading LVS.cxt
\o Loading acv.cxt
\o Loading auCore.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading seismic.cxt
\o Loading UltraSim.cxt
\p >
\a hiResizeWindow(window(1) list(287:14 1012:175))
\r t
\a ddsOpenLibManager()
\o cdsServIpc: ipcIsAliveProcess connection timeout (host:martian)Waiting for ipc:0 to initialize
\o Waiting for ipc:0 to initialize
\w *WARNING* (ddsOpenLibManager) unable to connect to library manager (60 tries)
\r cdsServIpc: ipcIsAliveProcess connection timeout (host:martian)nil
Can anyone tell me how to slove these problems?
cadence waiting for ipc:0 to initialize
Hi, everybody. I have solved these problems.
The reason for the problem is that the network card didn't work properly. When I activate the network card, IC5141 works well.
ic5141 restricted rights notice short form
I solved that problem on Suse 10.0_64, with linux32 icfb start command.
