C. Lee
Newbie level 1
failed attempt to annotate to non existent path
I finished gate-level synthesis. Then I dumped out .sdf and .v for gate-level simulation.
After I did the gate-level simulation with SDF timing annotation
I got the following error messages:
ncelab: *W,SDFNEP: Failed Attempt to annotate to non-existent path (IOPATH (posedge A) Y) of instance stimulus.pp.U89 of module XOR2X1 <./pingpong_syn.sdf, line 741>.
line 741 of pingpong_syn.sdf is
(IOPATH (posedge A) Y (0.074:0.074:0.074) (0.080:0.080:0.080))
corresponding info in .v file is
XOR2X1 U89 ( .A(n10), .B(flip), .Y(n9) );
I have no idea how to fix them since I don't know the reason for these messages.
Do I forget to set up something ?
Thanks a lot.
ps,
module XOR2X1 is as follow:
module XOR2X1 (Y, A, B);
output Y;
input A, B;
xor I0(Y, A, B);
specify
// delay parameters
specparam
tplh$A$Y = 1.0,
tphl$A$Y = 1.0,
tplh$B$Y = 1.0,
tphl$B$Y = 1.0;
// path delays
if (B == 1'b1)
(A *> Y) = (tplh$A$Y, tphl$A$Y);
if (B == 1'b0)
if (A == 1'b1)
(B *> Y) = (tplh$B$Y, tphl$B$Y);
if (A == 1'b0)
endspecify
endmodule // XOR2X1
Thanks a lot.
ps,
output Y;
input A, B;
xor I0(Y, A, B);
specify
// delay parameters
specparam
tplh$A$Y = 1.0,
tphl$A$Y = 1.0,
tplh$B$Y = 1.0,
tphl$B$Y = 1.0;
// path delays
if (B == 1'b1)
if (B == 1'b0)
if (A == 1'b1)
if (A == 1'b0)
endspecify
endmodule // XOR2X1
