Problem Installing Synopsys 2002 on RH9.0
FNK
Member level 3
Member level 3
I am trying to install Synopsy 2002.05 on RH 9.0. I tried using
export LD_ASSUME_KERNEL=2.4.1
and my installation is stucking at
WARNING: Invalid platform(s) LINUX. Skipping ...
Select platform(s) to install:
LINUX
Enter the list of platform(s) to install [LINUX]:
linux
Can anyone plz help me out.
Thanks
you can change your linux to version 7.*
LINUX
linux
Thanks
Just comment lines 51 and 52 in the install.now script and it should work....
Good luck! :wink:
Thanks Atre ...
I managed to go through that portion of the installation. However the installer is giving another error of not being able to uncompress the archive files. I think it is because uncompress is no longer there in RH9.
Can you adivce me how can I come along this error.
ln -s /usr/bin/gunzip /usr/bin/uncompress
are you unpackage your syn*.common.tar & syn*.linux.tar at same directory?
"mv LINUX linux" or "mv linux LINUX" as I posted in another thread.
