gauravkothari23
Advanced Member level 2
Hi all...
I have a very small issue....
i have written a code to send messages through SIM800 using SST89E516RD2 microcontroller.
code is:-
Now my problem is when i change
unsigned char Xdata phone[10]; to unsigned char phoneno[10];
i GSM module send me the messages...
but if i write
unsigned char Xdata phoneno[10];
the GSM modem does not send any messages.
the system only works and sends messages when array phoneno[10] is stores in DATA instead of XDATA.
why does this happen....
can you please help me....
code is:-
#include <sst89e516rd2.h>
sbit row0=P2^4;
sbit row1=P2^5;
sbit row2=P2^6;
sbit row3=P2^7;
sfr COL=0xA0;
unsigned char *message = "Hi Everybody "; // Content of the message to be sent
int keypad();
void sendsms();
void puts(unsigned char* ptr);
void putc(unsigned char chr);
void initialize();
unsigned char *std = "+91"; // std
unsigned char CTRLZ = 0x1A;
unsigned char xdata phoneno[10]; //Array to store the phone no.
void main() // MAIN STARTS HERE
unsigned int i,j;
while(1)
for(j=0;j<10;j++)
phoneno[i]=keypad(); // Entering new company phone no
LCD_putc(phoneno[i]);
i++;
i=0;
initialize();
msdelay(1000);
sendsms();
void sendsms()
puts("ATE0\r");
msdelay(1000);
puts("AT\r");
msdelay(1000);
puts("AT+CMGF=1\r");
msdelay(1000);
puts("AT+CMGS=\"");
puts(std);
puts(phoneno);
puts("\"");
puts("\r");
msdelay(1000);
puts(message);
msdelay(1000);
putc(CTRLZ);
int keypad()
unsigned char dat[4][4]={'1','2','3','A', // assigning key matrix
'4','5','6','B',
'7','8','9','-',
'*','0','#','+',
unsigned char colloc,rowloc;
COL=0xFF;
row0=0;
row1=0;
row2=0;
row3=0;
/* setting LCD screen*/
while(1)
/* reading character from keyboard */
do
row0=0;
row1=0;
row2=0;
row3=0;
colloc=COL;
colloc&=0x0F;
}while(colloc!=0x0F);
do
do
msdelay(10);
colloc=COL;
colloc&=0x0F;
while(colloc==0x0F);
msdelay(10);
colloc=COL;
colloc&=0x0F;
while(1)
row0=0;
row1=1;
row2=1;
row3=1;
msdelay(5);
colloc=COL;
colloc&=0x0F;
if(colloc!=0x0F)
rowloc=0;
break;
row0=1;
row1=0;
row2=1;
row3=1;
msdelay(5);
colloc=COL;
colloc&=0x0F;
if(colloc!=0x0F)
rowloc=1;
break;
row0=1;
row1=1;
row2=0;
row3=1;
msdelay(5);
colloc=COL;
colloc&=0x0F;
if(colloc!=0x0F)
rowloc=2;
break;
row0=1;
row1=1;
row2=1;
row3=0;
msdelay(5);
colloc=COL;
colloc&=0x0F;
if(colloc!=0x0F)
rowloc=3;
break;
if(colloc==0x0E)
return(dat[rowloc][0]);
else if(colloc==0x0D)
return(dat[rowloc][1]);
else if(colloc==0x0B)
return(dat[rowloc][2]);
else
return(dat[rowloc][3]);
void puts(char* p)
char *temp = p; /*temp pointer so that the actual pointer is not displaced */
while(*temp != 0x00)
putc(*temp);
temp++;
SBUF = chr;
while(TI==0); /*Wait until the character is completely sent */
TI=0; /*Reset the flag */
// MAIN ENDS HERE
void initialize()
SCON = 0x50; /*SCON: mode 1, 8-bit UART, enable receive */
TMOD |= 0x20; /*TMOD: timer 1, mode 2, 8-bit */
TH1 = 0xFD; /*TH1: for 9600 baud */
TR1 = 1; /*TR1: timer 1 run */
void msdelay(unsigned int value)
unsigned int i,j;
for(i=0;i<value;i++)
for(j=0;j<100;j++);
but if i write
