problem in starting spb15.2 !
binu G
Advanced Member level 2
Bangalore
cdscommon.dll
iam getting an error message
" The procedure entry point csfinitialize could not be located in the dynamic link library cdscommon.dll"
i tryed reinstalling but no way it worked.
regards
binu G
csfinitialize
I've also faced the same error msg when invoking projmgr manager, after I installed LDV5.1.
I need something to the env settings and overcome the error msg.
control panel -> system -> advanced tab -> env var
look for the path var under system var, move the LDV5.1 path to the end.
I think the problem is due to the sequence of installing Cadence products.
