[SOLVED] problem in samsung crt tv
pradeep.g.belchada
Full Member level 6
Full Member level 6
MUMBAI INDIA
hello, i have a problem in samsung crt tv
tv starts picture comes for 10 minutes , suudenly tv h synch loss appears, some tee sound ( like buzzer) comes from fbt . tv stops i mean
h-o/p stops. i changed fbt, o/p transistor, damper cap then also the same problem. tv model samsung plano 21 , ic used tda 9381
schematic below
  • cl21k3wf.pdf
i mentioned in the above post that line transformer (fbt) is replaced , yoke also replaced then also tv shuts down , when i remove yoke conector , h- section works
i had that prob with plano and sansui sets mostly that fault attacks flat screens,i am not sure which coil is exactly affected but i think is the horizontal ,just change the Scan Coils.
