more info are required to answer you.
Anyway a simple guess could be that for some reason you are not performing a frequency sweep analysis ...
Max
Actually I am doing simulation of LNA on Hspice RF,and seeing results on cosmoscope..but not getting
S-parameters plots correctly as ususally it should be..
I am attaching Spice code for LNA, please rectify my problem...
Thanks..
I am new in RF design and cadence spectre simulation. About the s parameter. what we should expect? In another word, in which range for the s parameter, indicate the LNA is good or bad?
I am learning RF design and that's my first assignment to design and simulate a LNA. I just caculated the parameters for simulation. But the simulation result is quite different from the caculated values. I change the load inductor to make the S11=-3.98dB, S12=-47.54dB, S21=11.737dB, S22=-7.29dB, K=14.65167, NF = 3.734dB.
I am not sure those figure is OK or that's a bad design.
Another thing is I also change the inductor to the Gate (Lg) smaller and I hope to check the input impedance if it is matching but I don't know how to do that in Spectre.
Can anyone give me some help?
