problem in rtc code pls help
mayur_marathe
Newbie level 3
Newbie level 3
pune
good morning everybody
i am doing a code in keil compiler for rtc using 8051 in C ,their are 16 digital inputs and 8 digital o/ps, and i have to show the counter status of each i/p pin on serial com. and used rtc for power on/off purpose means when power is off & again on then counter should start from previous ,i have learnt datasheet of ds1307& modified code so many times but i cant display the counter value on serial com .
serial comm code is ok.. i have attached the code.
pls help me
hi, that code contain only of IIC protocol, nothing else. no main function no serial initialisation, no i/o intialise etc
regards
kj
I didn't get time to check your code carefully. But I've done rtc using ds 1307. So I've working code of this. This might be useful to you. One more thing, you should know that ds 1307 works on bcd format. Check it out. Attachment has rtc, uart and i2c related functions. Dont focus on source file. That is only to call these functions for my use.
NIKS
he this code ll not work
NIKS
