speedEC
Full Member level 6
Dear all,
I am interfacing Barcode Scanner (USB) with PIC MCU thru' MAX3421E. I can able to connect and Enumerate the Scanner. But after that, I could not able to receive the barcode value from barcode scanner when reading. Barcode Scanner sounds good-read. It works well with PC (but we have to open a notepad or similar text editor to receive data).
I have enabled RWUIE (Remote Wake Up Interrupt) in MAX3421E and waiting for RWUIRQ interrupt to occur. When I read the barcode label and after barcode read it sends good-read, but RWUIRQ not interrupt occurred.
I have enabled RWUIE in HIEN register (R26) & IE in CPUCTL register (R16). I have tested the INT pin for other interrupts, for example Bus Reset, USB Disconnect, etc. All are working OK except, RWUIRQ.
I have SUSPENDED the Peripheral (Scanner) by seting the SOFKAENB = 0. So, after this I am waiting for either USB Disconnect or RWUIRQ occur. If I disconnect USB, interrupt correctly occur but only RWUIRQ DOES NOT.
USB Host Shield for Arduino used (for MAX3421E)., +3.3V
PIC MCU, +5V
BARCODE SCANNER(USB TYPE- BUS POWERED), +5V Given from adapter
LEVEL SHIFT USED between PIC and MAX3421E.
Any idea?
thank you.
Datasheet info added:
PIC MCU, +5V
Any idea?
thank you.
