Problem in pspice simulation
razeensab
Newbie level 2
Newbie level 2
C_C1         0 N05173  1n  TC=0,0
R_R2         N05403 N05221  1k TC=0,0
R_R1         N05221 N05281  1k TC=0,0
X_U3         0 N05173 N05249 N05281 0 N05173 N05221 N05281 555B
R_R3         N05173 N05403  8k TC=0,0
V_V1         M_UN0001 M_UN0002 24Vdc
X_U4         N05297 0 N05281 ADP3338AKC15RL PARAMS:
R_R12         N052611 N05249  1k TC=0,0
D_D1         N052611 0 LA_E63B-TYP
**** RESUMING 555.cir ****
.END
ERROR(ORPSIM-15141): Less than 2 connections at node M_UN0001.
ERROR(ORPSIM-15141): Less than 2 connections at node M_UN0002.
ERROR(ORPSIM-15142): Node M_UN0001 is floating
ERROR(ORPSIM-15142): Node M_UN0002 is floating
The error description is quite clear: Unconnected signals.
So what is your question?
Klaus
I can confirm that the said nodes are floating in the CIR file.
I guess you didn't enter the simulation circuit as netlist? So you would want to show the PSpice schematic the netlist is generated from.
Klaus
Hey Klaus,
I rectified the floating errors just now. Remaining 2 errors are there, which are
ERROR(ORPSIM-15141): Less than 2 connections at node N05740.
ERROR(ORPSIM-15141): Less than 2 connections at node N02200.
What does it mean ? should add some resistors on this node.?
