electronical
![Full Member level 1](/styles/images/ranks/elevel1.gif)
I use Design vision.in the setup part(file/setup), there is three type (fast,typical and slow with 1.32 ,1.2 and 1.08 supply voltage ) in 130nm cmos technology.
when I synthesis code, the result received for power, in slow type is bigger as typical type. while the supply voltage in slow is smaller than typical.
