Problem in Opening .text file with VB6
Bluestar88
Member level 3
Member level 3
Hi guys, I used the code below..The code seems to be correct but it doesn't work, in another word it doesn't enter to the loop..please help me...
Private Sub Command2_Click()
          Dim AllText, OneLine As String
          FileName = App.Path & "\" & Text1.Text & ".txt"
          MousePointer = 11
          Open FileName For Output As #1
          Form1.Text2.Text = ""
          AllText = ""
          Do While Not EOF(1)
             Line Input #1, OneLine
             AllText = AllText & OneLine '& Chr(13) & Chr(10)
          Loop
         Form1.Text2.Text = AllText
         Close #1
         MousePointer = 0
End Sub
hi,
The FileName looks incorrect.?
It would give Text1.text.txt .???
E
You should have Error trap code in the Subroutine
hi,
E
What does it mean about its name? please describe more.
I tested it, yet the condition of loop is false and it doesn't work (loop doesn't work)
Please help me...
hi,
Try this, the Text1.txt is located in the App.Path, you were opening the filename for Output
          Dim AllText, OneLine, filename As String
          On Error GoTo fail1
          filename = App.Path & "\[B][COLOR="#FF0000"]" & "Text1" & ".txt"[/COLOR][/B]
          MousePointer = 11
          Open filename For[B][COLOR="#FF0000"] Input[/COLOR][/B] As #1
          Text2.Text = ""
          AllText = ""
          Do While Not EOF(1)
          Loop
         Close #1
        MousePointer = 0
Exit Sub
fail1:
Text2.SelText = filename
End Sub
Dear esp1,
Thanks, You solved my problem...Thanks
