problem in nmea GPS string parsing
kulachi
Newbie level 5
problem in nmea parsing
hello all
i m doing a project of gps datalogger n i need to parse the gps sting
i m using Proton Development Suite compler to compile the code i m interesed in latitude and longitude of the string i m uploading my code but it not working it jst waits for the $GPRMC but dont get the string if any one can help me out with the error with this code or upload another code for the GPS NMEA parsing
i will b very thankful
Regards
Ali
Device 16F877A
XTAL 20
RSIN_PIN portC.7
RSIN_MODE true
SERIAL_BAUD 4800
INPUT PortC.7
Dim arr[50] As Byte
Dim long[50] As Byte
Dim i As Byte
Dim RsByte As Byte
Dim lat_d, long_d As Byte
Cls
Print "GPS Interfacing"
Delayms 1000
Main:
i = 0
RSIN WAIT( "$GPRMC" ) , RsByte
RSIN WAIT( "," ) , RsByte
arr[0] = RsByte
RsByte = Rsin
arr[1] = RsByte
RsByte = Rsin
arr[2] = RsByte
RsByte = Rsin
arr[3] = RsByte
RsByte = Rsin
arr[4] = RsByte
RsByte = Rsin
arr[5] = RsByte
RsByte = Rsin
arr[6] = RsByte
RsByte = Rsin
arr[7] = RsByte
RsByte = Rsin
arr[8] = RsByte
RsByte = Rsin
arr[9] = 0
;RsByte = Rsin
;RsByte = Rsin
lat_d = Rsin
RSIN WAIT( "," ) ,str long \10
long[11]=0
Print At 3,-3, str long " "
long[11]=0
Print At 4,-3, str long " "
Print At 2,1,lat_d," "
Goto Main
Re: problem in nmea parsing
Ok, I do not know which GPS receiver/module you are using, but I've made some things with Telit GM862 GPS module and I'm not parsing NMEA sentences instead I'm using another method, but here is a piece of code that you can analyse and figure out the way that I used to extract data:
ReadPosition:
	HRSOut "AT$GPSACP", CR
	HRSIn Wait ("$GPSACP: "), UTCh[0], UTCh[1], UTCm[0], UTCm[1], UTCs[0], UTCs[1]
	HRSIn Wait (","), Str Latitude\10
	If Latitude[0] = "," Then
		Print At 2, 1, "No GPS Lock"
		NoLock = 1
		High NoFixLED
		GoTo ExitIP
	EndIf
	NoLock = 0
	Low NoFixLED
	HRSIn Wait (","), Str Longitude\11
	HRSIn Wait (","), dummy
	HRSIn Wait (","), Str Date\6
	HRSIn Wait (","), Str NoOfSat\2
	GoSub Delay50
    ' setting up the module clock (RTC)
	If Clock = 0 Then
		GoSub SetupClock
	EndIf
ExitIP:
Return
HTH
    kulachi
