Problem in Matlab M-file programming
zapak
Junior Member level 2
Nepal
Hi! I have a small project requiring programming in MATLAB. While debugging, I noticed that for some reason, this software does not calculate the division of complex numbers very accurately. Because of this, there was a considerable difference in the answers calculated manually using a calculator and those produced by the program. As far as the correctness of the syntax is concerned, I'm pretty sure I've cleaned up all the mistakes after going through the codes countless number of times.
So, anyway! My question is : what is causing this inaccurate calculation of the division of complex numbers in m-file programs? Also, is there any way to improve the accuracy?(just like converting to a better solver as in case of Simulink)
Hi Zapak,
that is strange for me.
Have you an example that shows the inaccuracy you speak about?
Regards
Z
As the help of matlab says: All the computations in MATLAB are done in double precision.
So maybe you should change the accurate of the output. use command such as 'format long' or 'format long g', etc.
Ryan
zorro is right, zapak you should post the example and illustrate your problem. so far, I haven't found matlab has such problem
