problem in keil uversion3 when compiling the C programme
cont
Newbie level 2
Newbie level 2
Hi experts ,
i am using Keil uversion3. I wrote the program in c , but when compiling this programme it gave me these messages:
compiling pwm.c...
pwm.c(1): warning C318: can't open file 'regex.h'
PWM.C(3): error C129: missing ';' before 'pwm'
pwm.c - 1 Error(s), 1 Warning(s).
please tell me what to do and thank in advance
is the file 'regex.h'in the same folder as c file, if nt try tat i guess.
for other problem post the code here there is syntax error sumwhere perhaps.
Reactions: cont
    cont
Than you partzz for regarding my problem
the file 'regex.h' in the same folder as c, and here is the c prog
#include <regex.h>
#include <stdio.h>
viod pwm (unsigned char);
viod main
p2=0x00;
while(1)
unsigned char msec;
unsigned char nsec;
msec=100;
nsec=100-msec;
p2-0x01;
pwm(msec);
p2=0x00;
pwm(nsec);
void pwm(unsigned char ms)
unsigned int i;
for(i=0;i<ms<i++)
TMOD=0x01;
TH0=0xFC;
TL0=0x67;
TR0=0x01;
while(TF0==0x00);
TR0=0x00;
TF0=0x00;
If the header is in the same folder then use #include "regex.h" instead of #include <regex.h>
viod main
u hav written viod instead of void.
also post your code b/w # sign on top of your edit window
i hav microvision 4 and i hav my file in same folder as c and by compiler accepts both <font.h> and "font.h".is microvision 3 diff?
I don't have uvision3 but in uvision 4 it doesn't work (I just tried it) and this it the case with a few compilers I have worked with , <> searches in the predefined system path while "" searches in the same folder
I dont know what the hell you wrote..
[COLOR=#FF0000]#include <reg52.h>[/COLOR]
#include <stdio.h>
[COLOR=#FF0000]#define pw P2[/COLOR]
void pwm(unsigned char ms);
[COLOR=#008000]void main()[/COLOR]
[COLOR=#008000]pw=0x00;[/COLOR]
while(1)
  unsigned char msec;
  unsigned char nsec;
  msec=100;
  nsec=100-msec;
[COLOR=#FF0000]  pw=0x01;[/COLOR]
  pwm(msec);
  pw=0x00;
  pwm(nsec);
 unsigned int i;
 for(i=0;i<ms<i++)
   TMOD=0x01;
   TH0=0xFC;
   TL0=0x67;
   TR0=0x01;
   while(TF0==0x00);
   TR0=0x00;
   TF0=0x00;
Try this..
