Problem in Interfacing SIM 300 with 8051
mpatibandla
Newbie level 1
Newbie level 1
Guys I am currently on a project working with 8051, specifically AT89S52.
I want to send SMS to the GSM Module, in this case I have used SIM 300, whenever one pin of the 8051 gets high.
The GSM Module is working fine because it has responded to the commands when connected to the PC Hyper Terminal.
I am even sure about the hardware and circuit I have connected because I have checked all the voltage differences and they are exactly fine the way they need to be.
I think the problem lies in the code.
Here I am posting the code. Anybody who has already worked on this can kindly help me solving this
#include <REGX51.H>
unsigned char *command_AT = "AT\r";
unsigned char *command_CMGF = "AT+CMGF=1\r";
unsigned char *command_CMGS1 = "AT+CMGS =\"+918125883588\"\r";
unsigned char *message = "ALERT";
unsigned char CTRLZ = 0x1A;
void puts(unsigned char* ptr);
void putc(unsigned char chr);
void sendsms(void);
void initialize();
void delay();
int main(void)
P1 = 0x00;
P3 = 0x00;
while(1)
if(P1_0!=0x00 || P1_1!=0x00 || P1_2!=0x00 || P1_3!=0x00 || P1_4!=0x00 || P1_5!=0x00 || P1_6!=0x00 || P1_7!=0x00)
initialize();
sendsms();
P1=0x00;
return 0;
void initialize()
SCON = 0x50; /*SCON: mode 1, 8-bit UART, enable receive */
TMOD |= 0x20; /*TMOD: timer 1, mode 2, 8-bit */
TH1 = 0xFD; /*TH1: for 9600 baud */
TR1 = 1; /*TR1: timer 1 run */
IE=0X90;
void delay(int ms){
char k;
while (ms--)
for (k=0; k < 1; k++)
void sendsms()
puts(command_AT);
delay(1);
puts(command_CMGF);
delay(1);
puts(command_CMGS1);
delay(1);
puts(message);
delay(1);
putc(CTRLZ);
delay(1);
puts(command_AT);
void puts(char* p)
char *temp = p; /*temp pointer so that the actual pointer is not displaced */
while(*temp != 0x00)
putc(*temp);
temp++;
SBUF = chr;
while(TI!=0); /*Wait until the character is completely sent */
TI=0; /*Reset the flag */
try connecting your hardware to the PC and check if you are getting the commands sent on the hyperterminal. generally the problem lies in mismatch of baud rates.
