Problem in installing system generator?
I
iamme
Newbie level 1
how to install system generator
I install Xilinx ise 6.2 webpack & its updates.
But when i want to install system generator 6.1.1, It say core generator is not installed.
I check the installed xilinx. But it was not installed. Why?
Hi iamme
I think that for XSG 6.1.1 you need ISE6.2 or 6.1, but not ISE Webpack. Check Xilinx's website. There is no info about Webpack. If you want to try this soft you should request Eval version of 6.2.
Best reg
Install Xilinx ISE Foundation v6.2i
Install the following core generator
Install xilinxcorelib for simulation
You can obtain the above two by registering on xilinx website.
[quote="ramesh
Only do the above if you are using the xilinx cut down XE version of modelsim. If you are using the full Modelsim SE, then recompile the libraries with compxlib.
Git
There is not download option for Xilinx ISE Foundation v6.2i in its site. Only you must order CD.
