neazoi
Advanced Member level 6
Hello, I have made a small amplifier for HF (1-30MHz), operating in class-A.
The amplifier works ok if I continuously fed an input signal.
But when I try to switch on/off the input signal, the amplifier fails to respond quickly to these changes and it slowly increases it's output signal up to the maximum. This change takes as long as 1 sec to happen from min to max output signal.
What could the problem be?
