Problem in Generating Audio from AVR ATmega 32 micro-controller using PWM.
mayanksinha123
India
Hello folks,
my objective is to generate a playable audio which should sound "thank you" and "sorry" using ATmega32 micro-controller and a 2Watts 8 Ohms speaker with an RC filter in between controller and speaker.
i referred the following link and followed the procedure.
http://avrpcm.blogspot.in/2010/11/playing-8-bit-pcm-using-any-avr.html
As directed by the link above, i converted 'text' into 'speech' .wav file using ATnT, then converted it to 8000 samples mono 8-bit .wav file using 'switch', then converted it to c code and obtained the values...
i successfully dumped the code but i am getting hissing sound instead of desired audio at the output. I then built an Op-Amp Amplifier using LM358 which i connected between the micro-controller and the speaker but still not getting the desired audio. For Op-Amp Amplifier refer 5th circuit on following link.
http://www.techlib.com/electronics/audioamps.html#op-amp
kindly look into the matter and suggest the needful step for playing those files on ATmega 32.
Thanks and regards
Mayank Sinha
Did you try the original code to see if you can play that samples before trying to use your own samples?
Also in the given circuit the speaker is connected directly because the simulator uses the PC card.
The first link is not working. Kindly provide a new link.
It is working fine for me
https://avrpcm.blogspot.in/2010/11/playing-8-bit-pcm-using-any-avr.html
Here is the schematic
And code
  ATmega32 @ 8MHz
  Plays an 8bit/8000 sample PCM audio on OC1A output
#include <stdint.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include "pcm_sample.h"
#include <avr/interrupt.h>
#define SAMPLE_RATE 8000;
volatile uint16_t sample;
int sample_count;
/* initialise the PWM */
void pwm_init(void)
    /* use OC1A pin as output */
    DDRD = _BV(PD5);
    * clear OC1A on compare match
    * set OC1A at BOTTOM, non-inverting mode
    * Fast PWM, 8bit
    TCCR1A = _BV(COM1A1) | _BV(WGM10);
    * Fast PWM, 8bit
    * Prescaler: clk/1 = 8MHz
    * PWM frequency = 8MHz / (255 + 1) = 31.25kHz
    TCCR1B = _BV(WGM12) | _BV(CS10);
    /* set initial duty cycle to zero */
    OCR1A = 0;
    /* Setup Timer0 */
    TCCR0|=(1<<CS00);
    TCNT0=0;
    TIMSK|=(1<<TOIE0);
    sample_count = 4;
    sei(); //Enable interrupts
ISR(TIMER0_OVF_vect)
         sample_count--;
         if (sample_count == 0)
             sample_count = 4;
             OCR1A = pgm_read_byte(&pcm_samples[sample++]);
             if(sample>pcm_length)sample=0;
int main(void)
   pwm_init();
   while(1);//do nothing
The header file which plays "its working":
// pcm samples created by wav2c
//It plays "its working"
const long pcm_length=6800;
const unsigned char pcm_samples[] PROGMEM ={
    116,97,144,26,0,0,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,
    128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,
    128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,127,128,128,127,128,127,127,128,127,127,128,127,128,128,127,128,127,127,127,127,127,127,127,127,127,127,127,127,127,128,127,127,128,127,128,127,127,128,127,128,128,128,128,128,128,130,129,128,132,129,127,133,127,128,131,127,128,131,129,127,132,130,128,132,129,130,131,137,138,130,140,135,128,137,130,126,130,124,125,126,121,124,122,119,
    121,120,117,118,121,118,120,123,126,131,134,141,144,146,149,148,148,146,142,139,136,131,127,123,115,102,89,74,62,56,94,96,84,149,146,137,183,172,153,166,145,123,127,108,101,108,107,115,121,135,150,154,167,173,166,169,158,142,135,123,116,112,115,120,123,135,142,144,150,148,141,136,125,113,104,92,87,82,80,89,94,104,120,126,138,154,159,157,161,160,145,143,139,129,128,130,128,133,141,140,
    147,151,148,142,137,115,84,86,50,33,66,69,68,106,142,138,171,191,177,181,173,150,140,135,116,112,119,115,118,133,141,147,161,168,166,164,163,152,137,133,123,112,110,106,92,86,92,74,67,82,93,107,111,137,151,142,159,160,151,151,143,136,136,127,126,131,127,134,139,141,152,157,163,168,165,161,152,140,123,107,85,73,68,42,40,57,74,93,110,147,159,166,182,180,171,164,150,134,130,116,
    112,118,118,125,135,146,159,170,178,181,177,170,155,137,118,99,78,68,62,43,37,45,61,91,107,129,162,167,173,186,176,166,158,141,131,120,112,112,114,121,131,140,156,169,178,188,184,180,170,150,133,113,91,75,69,56,40,39,45,62,94,108,127,164,165,171,187,174,167,157,140,132,118,111,115,115,124,136,146,162,177,186,190,188,180,166,145,125,104,81,72,61,40,34,33,42,73,90,107,143,
    156,165,182,182,178,170,156,146,132,119,117,115,119,126,134,149,162,174,183,185,184,175,161,144,123,103,84,74,62,44,37,41,54,77,88,113,147,141,159,181,169,173,171,160,153,136,131,131,121,125,132,133,143,152,163,168,166,171,165,149,139,125,108,93,90,87,76,73,74,82,90,91,102,114,117,121,133,140,144,149,152,153,148,144,144,142,140,139,142,144,143,146,147,144,141,140,135,130,127,125,
    123,120,121,123,121,118,116,115,115,114,112,112,111,110,111,112,114,117,120,124,128,130,133,135,136,137,139,141,143,144,143,143,142,140,139,138,136,135,134,133,132,132,131,131,130,129,128,127,126,125,123,122,120,117,115,114,112,111,111,112,114,115,117,120,122,124,126,129,131,133,135,136,138,139,139,139,139,138,138,137,136,135,134,133,132,132,131,130,129,128,128,127,127,126,125,125,124,123,123,122,
    122,122,122,122,122,122,123,124,124,125,126,127,128,128,129,130,130,130,131,131,131,131,131,130,130,130,130,129,129,129,129,129,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,129,129,129,129,129,129,129,129,128,128,128,128,128,128,128,128,128,128,128,128,128,127,127,127,127,127,127,127,127,127,127,127,128,128,128,128,
    128,128,128,128,128,128,128,128,128,128,128,129,129,129,129,129,129,129,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,
    128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,129,128,127,129,
    130,128,127,128,128,127,127,128,128,127,128,128,128,128,128,128,128,128,128,128,128,128,127,128,128,128,128,128,127,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,127,128,128,128,128,128,128,128,128,128,128,129,128,128,128,128,128,128,129,129,127,128,128,127,128,128,128,128,128,128,128,128,128,128,128,128,128,127,128,128,128,128,128,129,128,127,128,128,
    127,129,128,129,129,128,128,127,129,127,128,127,127,128,128,129,128,129,128,128,128,128,128,127,128,128,128,128,128,130,128,129,127,128,128,127,127,128,129,127,129,128,129,128,127,128,128,126,130,129,127,127,128,128,128,126,129,129,128,128,129,129,128,127,128,129,128,126,128,128,129,127,130,128,129,125,129,127,127,129,126,131,125,131,128,130,126,130,126,127,128,129,129,129,126,128,130,125,129,127,
    129,126,128,124,129,129,130,131,125,126,128,129,126,130,127,130,129,126,130,127,125,125,130,128,127,129,127,131,125,127,129,128,128,127,128,127,130,126,126,125,127,129,129,130,128,130,126,130,128,131,130,128,128,125,129,126,130,127,130,130,127,128,128,130,127,130,126,130,130,125,128,128,130,129,128,125,127,130,125,129,127,129,132,128,127,126,130,126,128,129,127,130,127,128,127,128,126,127,131,126,
    129,126,124,131,128,127,128,129,127,130,127,123,133,127,129,132,127,129,128,128,124,129,126,127,131,123,129,131,130,130,128,129,129,129,121,128,130,126,130,126,127,132,130,125,129,130,125,129,123,124,132,128,125,129,129,128,131,129,124,129,129,127,130,127,128,132,129,125,128,130,127,126,128,129,127,126,127,128,129,126,127,130,130,129,126,129,130,127,128,127,128,129,128,128,130,130,127,128,128,128,
    129,127,126,128,130,127,128,129,129,129,127,128,128,127,127,127,129,128,129,129,129,128,126,128,127,126,129,129,128,129,129,128,128,128,127,128,127,128,128,127,127,128,129,128,128,127,128,129,128,128,127,127,128,129,128,128,128,128,129,128,128,128,129,129,128,128,128,127,127,128,128,128,129,128,127,128,129,128,128,127,127,129,129,128,127,127,128,129,129,128,128,129,129,128,128,129,127,128,128,128,
    128,128,128,128,128,128,128,127,127,127,128,128,127,128,128,128,127,126,128,128,129,128,128,128,129,128,129,129,128,129,129,128,128,128,129,129,128,128,128,129,128,128,127,128,128,129,128,127,127,127,127,128,128,128,128,128,127,128,128,128,128,128,127,127,128,129,128,128,128,128,128,128,129,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,
    127,127,128,128,128,128,128,128,128,129,128,128,128,128,129,128,128,128,128,128,128,128,129,128,128,128,128,128,127,127,127,128,128,128,128,128,127,127,128,129,129,128,128,128,128,129,129,129,128,128,129,129,129,129,128,128,128,128,128,128,128,128,128,127,128,128,127,127,127,127,127,127,127,128,128,128,128,128,128,128,128,128,128,128,128,129,129,129,129,129,129,129,129,129,129,129,128,128,128,129,
    129,128,128,128,127,127,128,128,127,127,127,127,127,127,127,127,127,127,127,127,127,128,128,128,129,129,129,129,129,128,129,129,129,130,129,128,128,129,129,129,129,129,128,128,128,128,128,128,127,127,127,127,127,127,127,127,127,127,127,126,126,127,127,127,127,128,128,128,128,129,130,130,130,130,130,130,130,130,130,130,130,129,129,129,129,129,129,128,127,125,125,125,125,124,124,124,124,125,125,125,
    125,125,126,127,128,129,129,130,130,131,132,132,132,132,132,133,133,133,133,132,131,131,131,131,130,129,128,126,124,124,124,123,122,121,119,118,119,121,121,121,122,124,126,129,132,133,134,134,135,135,137,138,139,139,138,137,138,139,139,139,137,133,130,129,128,127,123,117,111,107,104,101,98,93,89,92,105,123,138,145,146,143,140,141,146,150,146,137,129,125,127,136,147,154,155,152,149,147,145,144,
    141,133,123,115,110,107,105,102,95,84,75,75,88,111,132,146,153,152,145,140,142,144,141,136,131,123,117,121,133,143,151,155,154,148,144,144,145,144,139,131,120,112,111,115,119,119,113,99,85,76,72,83,109,135,148,152,149,145,143,148,152,147,135,123,115,115,126,141,150,150,147,145,145,149,154,153,142,129,120,115,117,122,124,120,112,104,94,88,84,80,85,105,129,144,151,152,149,145,145,146,
    140,129,119,115,117,127,140,148,148,145,145,147,149,150,146,136,125,120,121,123,125,126,123,118,114,110,103,94,84,74,81,108,138,153,154,149,146,146,151,154,143,124,111,111,121,135,147,149,142,138,144,153,156,152,141,127,118,119,126,129,124,119,117,119,122,121,111,94,82,72,75,98,130,147,144,139,142,151,156,156,143,122,107,110,125,136,140,139,138,139,148,159,160,148,135,128,126,128,130,128,
    122,118,123,131,133,128,118,107,97,91,82,77,90,119,142,147,146,147,152,153,152,144,126,111,109,120,130,135,136,138,141,148,155,156,146,135,129,129,129,128,124,120,118,124,132,134,129,121,114,107,100,90,76,73,97,132,150,147,141,145,154,158,152,137,117,106,113,128,136,134,133,139,148,156,159,151,138,130,131,134,129,121,117,118,124,132,136,133,125,120,118,114,102,89,75,67,84,120,150,149,
    137,138,155,164,156,137,116,106,109,124,133,131,128,137,152,161,158,149,141,135,134,135,130,120,115,121,131,135,134,132,132,131,130,124,112,98,87,83,77,82,106,139,152,146,143,153,162,154,137,120,110,109,116,127,131,131,137,150,159,157,149,142,137,133,128,125,121,118,121,128,134,134,133,133,134,130,123,115,106,98,91,85,77,80,106,142,158,149,140,148,161,157,137,117,108,110,119,130,134,133,
    138,153,164,160,145,136,136,136,130,123,120,121,126,133,137,136,132,132,134,132,123,113,106,102,99,94,86,78,86,118,152,159,142,134,146,160,150,125,108,107,115,124,131,134,136,144,156,162,153,138,132,135,135,128,120,120,126,133,137,137,136,134,136,136,131,121,112,110,109,106,99,93,87,87,107,139,158,148,133,137,153,156,133,111,108,118,125,126,130,136,143,150,155,152,140,131,132,135,131,121,
    118,126,134,136,133,133,136,136,133,128,122,116,112,112,109,105,100,97,92,90,109,140,159,147,132,136,154,156,133,112,111,122,129,130,131,136,144,151,154,148,137,131,134,136,130,121,122,131,137,134,131,132,136,135,130,124,120,117,114,111,106,104,101,98,89,88,111,146,159,141,127,139,159,155,126,108,113,127,131,127,128,138,147,153,152,145,136,134,138,137,128,119,124,134,139,134,132,135,139,137,
    129,123,120,118,116,112,107,102,100,98,91,90,113,146,156,138,127,141,159,151,123,108,116,128,128,125,127,136,146,151,149,141,133,134,139,135,125,120,128,136,136,130,130,136,138,134,128,124,121,118,114,110,106,103,100,95,87,94,123,151,151,133,131,151,162,144,119,113,124,131,127,124,129,139,148,150,146,139,137,141,140,131,123,125,132,133,129,128,133,137,136,132,129,125,121,117,112,107,103,100,
    96,87,84,104,136,151,138,129,143,163,156,130,117,123,131,128,121,122,131,142,149,147,140,139,146,147,138,126,126,132,134,129,126,129,134,137,135,131,126,125,123,118,109,104,103,100,91,83,93,122,144,139,128,137,157,160,141,125,124,131,130,123,118,122,134,143,143,138,138,146,149,142,131,129,133,133,128,125,126,131,134,133,130,127,127,127,123,115,109,108,105,98,89,90,109,131,134,127,130,147,
    158,149,135,131,135,136,130,122,120,128,137,138,134,134,142,147,144,137,134,135,134,131,127,125,126,129,131,129,126,127,129,126,120,116,115,113,108,103,99,103,115,125,125,123,130,142,146,140,136,137,140,137,130,126,127,130,132,131,129,132,137,139,137,134,135,135,134,130,128,127,127,128,128,126,126,127,128,126,124,124,124,123,121,120,120,120,120,121,122,124,125,126,126,128,129,129,129,129,130,130,
    129,129,129,129,129,129,129,129,130,130,130,130,130,130,130,130,130,130,130,130,129,129,128,128,128,127,127,127,127,127,127,127,127,127,127,127,127,128,128,128,128,128,128,128,129,129,129,129,129,129,129,129,129,129,129,129,129,129,129,129,129,129,128,128,128,128,128,128,128,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,
    128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,131,132,129,126,126,127,127,127,127,127,128,128,129,129,129,128,129,129,129,140,124,114,133,131,119,128,133,124,123,127,143,130,117,143,133,116,132,134,
    118,124,131,127,130,127,125,130,131,126,128,131,125,126,130,126,125,129,128,125,129,128,126,128,128,127,127,129,129,129,127,127,128,130,132,127,127,129,126,127,130,127,126,129,128,127,129,129,127,129,128,131,135,128,128,130,127,126,127,126,125,127,127,127,128,128,128,129,129,127,128,128,127,127,126,127,127,127,128,127,128,128,129,129,129,129,129,129,129,130,129,130,130,129,129,129,129,129,129,129,
    129,128,128,128,127,127,127,126,126,126,125,126,125,124,125,123,123,125,123,124,126,124,127,128,128,130,130,131,133,132,133,134,133,134,134,133,134,134,133,134,133,133,133,131,131,131,128,129,127,125,125,122,121,120,117,117,115,112,113,112,111,114,113,116,121,121,127,132,134,140,142,143,147,146,146,146,144,143,142,139,140,139,138,139,139,138,139,136,135,133,129,125,120,114,108,102,95,91,85,84,
    87,88,98,105,112,127,133,142,153,152,157,157,151,151,144,139,137,132,131,133,134,139,145,147,152,154,153,153,148,143,138,131,125,119,115,111,108,108,106,104,103,97,94,93,93,94,99,105,109,120,127,135,147,150,154,158,153,152,149,141,139,134,129,131,131,132,138,140,144,148,148,148,148,143,139,137,129,127,124,119,119,116,114,115,113,111,108,102,97,94,92,91,96,101,108,118,126,136,146,150,
    156,156,154,152,146,141,136,131,129,128,130,133,137,142,146,149,152,150,150,146,141,138,131,127,124,118,118,115,113,115,113,111,109,103,98,95,91,91,94,97,106,113,123,133,141,149,153,155,155,151,149,143,139,136,132,132,133,135,140,143,147,150,151,151,149,146,141,136,131,126,122,118,115,113,112,111,110,109,106,102,96,93,91,91,96,100,107,117,124,135,143,149,154,155,153,151,147,143,139,135,
    134,134,135,138,141,144,148,150,150,150,147,143,140,134,129,127,122,120,119,115,116,115,111,113,109,104,102,95,93,93,93,99,105,112,121,129,138,143,148,151,149,150,146,141,141,135,134,135,133,138,140,142,147,148,148,149,147,145,142,138,133,130,127,123,123,121,119,120,116,115,116,109,107,104,94,95,91,90,98,100,110,119,125,136,141,145,150,148,147,146,141,139,136,134,135,134,137,141,143,147,
    149,150,151,148,146,143,138,135,131,127,126,123,122,122,121,120,118,116,114,110,106,101,96,94,91,94,98,102,112,119,127,136,140,144,147,146,146,144,140,139,136,135,136,136,138,141,143,147,149,150,150,148,146,143,138,135,131,127,126,124,123,123,121,121,120,117,115,111,107,102,97,94,91,91,95,101,107,117,124,131,139,142,145,147,144,144,142,138,138,135,135,137,138,141,145,146,149,151,150,150,
    147,143,140,136,132,129,126,125,123,122,123,121,121,121,118,115,112,106,101,97,92,92,92,96,104,109,119,127,132,141,143,145,147,143,142,140,136,136,135,134,137,138,141,145,147,150,151,150,149,146,143,140,135,132,129,126,125,124,123,124,123,122,121,120,116,113,108,102,100,95,94,95,96,103,108,115,123,128,135,139,141,144,142,142,140,138,137,135,136,137,137,141,142,145,148,148,149,148,145,144,
    140,137,135,130,129,127,125,127,125,124,124,122,121,120,116,114,110,105,103,99,98,98,99,103,108,113,120,126,130,136,138,139,141,139,139,138,135,136,136,135,139,139,141,145,145,148,148,147,147,144,142,140,136,134,131,129,128,127,126,125,124,123,122,121,119,117,114,110,106,102,99,98,98,100,104,108,114,120,125,130,134,137,139,140,139,139,138,137,137,136,137,138,140,142,144,146,147,147,147,146,
    144,142,139,136,133,131,129,128,127,127,126,125,124,123,122,120,118,115,111,108,105,101,100,100,100,104,107,112,118,122,128,132,134,137,138,138,139,137,137,137,136,137,138,139,142,143,144,146,146,147,146,144,143,140,137,135,132,130,129,128,127,126,126,125,123,122,121,119,117,114,110,107,104,102,100,100,102,106,109,114,119,123,128,131,134,137,137,138,137,137,137,136,137,138,138,141,141,143,145,145,
    146,145,144,144,141,139,137,135,133,131,130,129,128,128,127,125,124,123,121,120,117,115,112,108,106,103,102,102,103,105,108,112,116,120,125,128,132,134,136,137,138,138,138,138,138,139,139,140,141,142,143,144,144,144,144,143,142,140,138,136,134,132,131,130,129,128,127,126,125,123,122,120,118,116,114,111,108,105,104,103,103,104,107,110,114,118,122,126,130,133,135,137,138,138,138,138,138,139,139,140,
    140,141,143,143,144,144,144,143,142,141,139,137,135,133,131,130,129,128,128,127,126,124,123,122,120,118,115,112,109,107,104,103,102,103,106,109,112,116,121,125,129,132,134,136,137,137,137,137,137,138,138,139,140,141,142,143,143,144,144,143,142,141,139,137,135,134,132,130,129,129,128,128,127,126,125,123,122,119,117,115,111,109,107,104,103,103,104,107,110,114,118,122,126,130,132,134,136,136,137,137,
    137,137,137,138,139,140,141,142,143,143,144,144,143,142,140,138,137,135,133,131,130,129,129,128,128,127,126,125,123,121,119,117,114,112,109,107,106,106,105,106,108,112,115,118,122,125,128,131,133,134,135,136,136,137,137,137,138,139,140,140,141,142,142,143,142,142,141,139,138,136,135,133,132,131,130,129,128,128,127,126,125,123,122,120,118,116,114,112,110,108,107,106,107,108,110,113,117,120,124,128,
    131,133,134,135,136,137,137,137,137,137,138,139,139,140,141,142,142,142,142,141,140,138,137,135,134,132,131,130,129,129,128,128,127,126,124,123,121,120,117,115,113,111,109,108,107,107,108,110,112,115,119,122,125,128,131,133,134,135,136,136,136,137,137,137,138,139,140,141,142,142,142,142,141,141,139,138,136,135,133,132,130,129,129,128,127,126,125,124,123,121,119,117,115,113,111,109,108,108,108,109,
    110,113,116,119,123,126,129,131,133,134,135,136,136,136,136,137,137,138,139,140,141,142,142,142,142,141,140,139,137,136,134,132,131,129,128,128,127,126,125,124,123,122,121,119,117,114,113,111,110,109,109,109,110,111,114,118,121,124,127,130,132,134,135,135,136,137,137,137,137,138,138,139,140,141,142,142,142,141,140,139,137,136,134,132,131,129,128,127,127,126,125,124,123,122,121,120,118,116,115,113,
    112,112,111,111,112,113,114,116,119,122,125,128,130,132,134,135,136,137,138,138,138,139,139,140,140,141,141,141,141,140,140,139,137,136,134,132,130,129,127,126,125,124,123,122,121,120,119,118,116,115,114,113,113,112,113,113,114,116,118,120,123,125,128,130,132,134,135,136,137,138,138,139,139,139,139,140,140,140,140,140,139,139,137,136,135,133,131,129,128,127,126,125,124,123,123,123,122,121,119,118,
    117,116,114,114,114,114,114,115,116,117,120,122,124,126,128,130,132,133,135,135,136,137,138,138,139,139,140,140,140,140,140,140,139,138,137,135,133,132,130,129,127,126,125,124,123,122,121,120,120,119,118,117,116,116,115,115,115,115,116,117,119,121,123,126,128,130,132,133,134,135,136,136,137,137,137,137,137,138,138,138,138,138,138,137,136,135,134,132,131,129,128,127,126,125,124,124,123,123,122,121,
    121,120,119,119,118,118,118,118,118,119,119,120,122,123,125,126,128,129,130,131,132,133,134,134,135,135,136,136,136,137,137,137,137,136,136,136,135,134,133,132,131,130,129,128,127,126,125,124,123,123,123,122,121,121,120,120,119,119,119,119,120,120,120,120,122,123,124,126,127,129,130,131,132,132,133,134,134,134,135,135,135,136,136,136,136,136,135,135,134,133,133,131,130,129,128,127,127,126,125,125,
    125,124,124,124,124,124,124,123,122,122,121,121,121,121,121,122,122,123,125,126,127,128,129,130,130,130,131,131,131,131,132,132,132,133,133,133,133,134,133,133,133,132,131,131,130,130,129,128,128,128,127,127,127,127,126,126,126,126,126,125,125,124,124,123,123,123,123,123,123,124,124,125,126,127,128,128,128,128,129,129,129,129,130,130,130,131,131,132,132,133,133,133,133,132,132,131,130,130,129,129,
    128,128,128,128,128,128,128,128,128,127,127,126,126,125,125,125,125,125,125,125,125,125,126,126,127,127,128,128,128,128,128,128,128,128,128,128,128,129,129,129,129,129,130,130,130,130,130,130,129,129,129,129,128,128,129,129,129,129,129,129,129,128,128,128,128,128,128,127,127,126,126,126,126,126,127,127,127,127,127,127,127,127,127,128,128,128,128,128,128,128,128,129,129,129,129,129,129,129,129,129,
    128,128,128,128,128,128,128,128,128,129,129,129,128,128,128,128,128,127,128,128,128,128,128,128,128,128,127,127,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,
See. I am getting this. Can somebody provide the include files, so that I can check. The first link is not opening in my chrome and IE.
Try this. See, if it works.
Sir, yes i tried the original code but that time also i was getting hissing sound at the speaker end.
Is there a problem with this filter circuit? what circuit should i use between my micro-controller and speaker. i tried using op amp amplifier according to the link 2 but still not able to achieve desired audio output.
The link is not working for me. Please upload a copy of the page.
Try this if it works. https://extremeelectronics.co.in/avr-tutorials/sound-generation-by-avr-micro-tutorial-i/
i have already tried that tutorial, but i m getting some hissing noise at the output. initially i directly connected 2Watts 8 ohm speaker with ATmega 32 micro-controller but i was not able to obtain the clear output moreover speaker was fetching a high current so my senior suggested that connecting a speaker directly with microcontroller is not a good practice.
can u suggest me which kind of circuitary shall be used between micro controller and speaker 1W/2W 8 ohms so as to achieve clear audio.
thanks and regards
@ internetuser1k12
here is a copy of that link which u were not able to open.
  • PWM audio using ATmega32.rar
can you send the header file pcmsample.h. I will try to compile it in avr studio 6 and see.
