problem in executing
Arindam123
Newbie level 1
Newbie level 1
hey there,
i am trying to simulate the mod operation in modelsim and i am not getting a proper output.
my code is
entity divi is
port( a,b : in std_logic_vector(15 downto 0);
y : out std_logic_vector(15 downto 0)
end divi;
architecture ber of divi is
signal a1,b1,c1 : integer;
signal temp: std_logic_vector(15 downto 0);
begin
process(a,b)
begin
a1<= conv_integer(a);
b1<= conv_integer(b);
c1<= a1 mod b1;
temp <= conv_std_logic_vector(c1,16);
y<= temp;
end process;
end ber;
the values of a ab b are "0000000000001100" and"0000000000000111"
i am getting a1,b1,c1 all zeroes.
can anyone help me out where the problem is???
problem is that the process sensitivity is only on a and b. when a,b changes one time, only C1 changes but temp is loaded by last value of temp that is zero. and also y gives temp last value that is zero.
I suggest you one of these:
1) use a clock or
2) add other signals to process sensitivity list.
like :
process(a,b,a1,b1,c1,temp,y)
3) Do not use process. like this
begin
c1<= a1 mod b1;
y<= temp;
initialize the integer values and use delays in process
