Problem in custom transformer in Proteus
fem21
Newbie
Newbie level 1
Hi All,
For my SMPS project, I made a custom transformer in proteus 8.1. I took the base transformer model TRAN-2P3S from standard Proetus library and modified to TRAN-2P6S (with 6 secondary). Before integrating this custom made transformer, I tried to test it by applying the square pulse through a pulse generator. The original one gives the output but custom made transformer doesn't. Though I defined all I/P and O/P points in child sheet. Can some one pls help me?
Pls download the circuit from below link...I defined the child sheet also in test simulation.
[Moderator action: removed link to file server]
The simulation file is also attached with the message.
Thanks for your help in advance guys.
Best regards
Prakash
  • tranasformer-rv01.zip
