Problem in connecting two computers(network cable unplugged,
h.v
Junior Member level 2
Hello
My problem started when I bought a laptop (asus f83vf) and I wanted to make it connected to my PC(with onboard LAN connector on it), in order to do that I bought a 5m cross over cat5e cable .
And I did some configurations on them
Here is my configurations:
==========PC============
IP: 192.168.1.2
Mask: 255.255.255.0
802.1p Support on
Flow Control enabled
Interrupt Moderationenabled
Jumbo Packet  1514 Bytes
Log Status Messages Status Messages
Max IRQ per Sec 1000
Network Address no Present
Receive Buffers 496
Speed & Duplex 10 Mbps Half Duplex
TCP/UDP Checksum Offload (IPv4)  off
Transmit Buffers 176
Wake From Shutdown on
Wake-Up Capabilities Magic Packet & Pattern Match
Power managementAllow the computer to turn off this device to save power. uncheck
IPCONFIG: ============
C:\Documents and Settings\V>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 9:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Marvell Yukon 88E8001/8003/8010 PCI
Gigabit Ethernet Controller
Physical Address. . . . . . . . . : 00-0F-EA-EA-C3-A6
========== Lap ============
ip:192.168.1.1
Mask: 255.255.255.0
Flow Control on
Large send offload on
Ipv4 checksum offloadoff
Max IRQ pers sec1000
Media type10 Mbps Half Duplex
Number of Rx Buffers 496
Number of Tx Buffers 176
C:\Documents and Settings\h>ipconfig/all
Host Name . . . . . . . . . . . . : hexa-windows
IP Routing Enabled. . . . . . . . : Yes
Ethernet adapter Wireless Network Connection:
Description . . . . . . . . . . . : Atheros AR9285 Wireless Network Adapter
Physical Address. . . . . . . . . : 1C-4B-D6-59-20-DD
Ethernet adapter Local Area Connection 3:
Description . . . . . . . . . . . : Atheros AR8132 PCI-E Fast Ethernet C
ontroller
Physical Address. . . . . . . . . : E0-CB-4E-82-15-CF
The problem is that my LAN network does not work. In Network Connections, it has the status: " network cable unplugged." When I enable it
and ipconfig /all returns:
Media State ........ : Media Disconnected.
***** a very strange thing happens when I disable /enable Local Area Connection on PC before enabling Local Area Connection for a second it shows "connected"!!!!! But it changes to "network cable unplugged" again.
*** I did some research to try and fix the problem and this is what I did:
1-Turned off firewall
2-Update both drivers to latest version
3-reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
4-Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
5-test cable with multi-meter and make sure it is OK & a crossover cable
6-reinstal win xp
7-change configuration of both systems listed above many times but it didn’t work.
8- these commands work OK on PC and LAP
"ping 127.0.0.1"
"ping localhost"
Re: Problem in connecting two computers(network cable unplug
Hello.... i saw you topic and i would like to help although it's been a while.
i think your problem resides in the hardware level, so nothing to configure since regardless of the ip configuration you should get a "plugged in" network card whenever u plug it to another computer or switch, then the configuration comes later on to allow the connectivity in order to reach the other computer.
So i think u either have a stright throw cable which u need to replace it with a cross over one, or one of your network adapters in mulfunctioning.
Check the RJ-45 wire colors to check if it is really a cross over cable, the orange and white orange wires on one end should be replaced with green and white green wires on the other side and vice versa.
good luck
thanks for your reply ,i still have that problem!
i am SURE the cable IS an CrossOver one i checked it with my Multimeter(and the colors are replaced as you said.)
what did you mean by "or one of your network adapters in malfunctioning"????????
how should i find the thing causing this???
hello again,
so the cable is ok...sorry for the typing mistake, i meant one of your network adapters is malfunctioning which is either the laptop or the desktop
i suggest to try with another computer, maybe a third laptop(or a switch) from a friend and connect it first to your laptop and check if it shows plugged it, and then connect it to your pc and check the same. this will narrow down the options and know which adapter is working and which is not.
regards...
