Hi, i've set up a TRF7960 pcb to read a Mifare card. I'm using a pic18F2550 with SPI mode and i've already complete an anticollision sequence following the ISO14443A standard to get the complete UID of the card and to select it.
Now, I should start the mutual authentication with the card, Im able to get the tagNonce of 4bytes but then i should reply doing the framing manually because the trasmission is encrypted and also the parity bits are encrypted, so I must switch to the DIRECT mode bypassing the protocol implementation in the TRF7960.
Anyone have the same problem? we can work togheter! let me know
