sweetest_loo
Newbie level 1
ansoft ensemble manual book
Hi!! I am a new member. Currently i am using the Ansoft Designer and Ansoft Ensemble to design a rectangular microstrip antenna. I am not sure about the use of interface port and transmission line (in microstrip) for Ansoft Designer. Is that a must to include the interface port and transmission line in the design?
What is the difference between Ansoft Designer and Ansoft Ensemble?
The width and length calculated from Ansoft Designer is different from the calculation provided in Balanis Antenna book. Why? I should trust which 1?
What is S parameter. i have gone through the help in Ansoft Designer and Ansoft Ensemble but i can't find the explanation for S parameter.
Thank you!
Thank you!
