Problem encountered during connection to Sun Solaris server
tedybear
Newbie level 5
Newbie level 5
When i connected the work station using Exceed,
it did not work.
My workstation is Sun solaris 9.0
Cadence IC 5.1
I type these commands
setenv DISPLAY 192.168.1.174:0.0 *****PC ip is 192.168.1.174
icfb&
It shows that :
warning,/vol is locked
atr,can not handle 24 planes
What does it mean?
Eager for your help
3Q
Re: Problem encountered during connection to Sun Solaris ser
Hi !!
is go the connect to sun through the console or the broadcast ?
though
console
though broadcast of Exeed's try !
could you please tell me where to config
broadcast
3x
It's not config
Run not Exeed, and Exeed(XDMCP-Broadcast) in Start/programms/Exeed....
The window will open where must be you sun
You are press to sun row and start CDE of solaris
r u type 'xhost +' on workstation?
which version of exceed r u use? better higher than 7.
set graphic card in 8 bits mode
