problem defining substrate(infinite in half space) in HFSS
yanr_1612
India
Hi all
I am working on antennas using HFSS 9.
Can anyone tell me the procedure to define a substrate that is infinite in half space? That is infintie length infintie width and infintie height.
Kind Regards,
Arun.
I need the same thing: drawing two half spaces facing each other...the only infinite thing I found was the ground plane, but separating an half space from the other by it means imposing a screen that prevent backscattering of waves.
Another thing Inoted was that the simulator divide the space into two regions, the one said 'space of the problem' in which it computes the fields...etc and the other said 'space of the mesh' in which it generate a mesh without computing anything.The outer is called background...
Re: problem defining substrate(infinite in half space) in HF
sorryu
