Adbadb
Junior Member level 1
I want to use ATtiny2313 and ULN2003 to control a 7 segment display, there are resistors on the segments of the display, it works with common Anode +24v.
The ULN2003 has the inputs connected to the IC and the outputs to the display,
the GND is connected to the Ground and the COM to +24. I noticed that when the GND from the 24v supply and the GND from the 5V supply are conected together the ULN2003 works like it should, but the output pins from the ATtiny2313 does not work, and when the GND are not connected with each other the output pins from the ATtiny2313 give +5V but now the ULN2003 is not working.
What could be the problem?
