gdhp
Hi all!
i am a fresh man of analog designer, i have a problem to ask!
In my knowledge, if there are two ways between the input and output, a zero is arise. Now i am designing a folded cascode amplifier(as below). i use the '.pz' to simulate the all zeros and poles. From the log results, i found several zeros, and i don't know where the zeros come from!
so i want to know how to expect the zeros in the amplifiers! Should i consider al l the parasitic cap and then calculate the transfer function?
By the way, in the folded cascode amplifier, i found a dominate pole, and several higher poles and zeros. what fuzzled me is every higher poles is equally with the corresponding zeros. So in the amplitude vs freq bode diagrams, the amplitude is decrese at the dominate pole and then don't change after a higher pole until the frequency reach seral G. SO i want to know how the results arise!!
Last, thanks a lot!!
