print adress in ARM CORTEX m3
manijohn
Newbie level 3
Newbie level 3
Good Evening to all,
i am using LPC1788 arm cortex m3 micro-controller ..and my problem is print SDRAM address...how to print the address in IDE...kindly send me the code or suggest any ideas
thanks & regards
D.manivelan
Assuming you are programming that 32-bit microcontroller in C, obtaining of such information could be done through compiler directives whose syntax may vary from one compiler to another. Anyway, this information is absolutely useless at all on this programming language, since the management of the memory allocation is done through the compiler itself. The only information that would make sense you know on this regard is how much free SDRAM memory remains in runtime.
'*value' is a pointer value, and 'value' is a pointer address if value is declared as pointer: void * value
Simply check that in debug mode.
For SDRAM (DynamicRam) in LPC 1788 , the addresses are mapped into
0xA000 0000 - 0xAFFF FFFF (as 1st block) and continued to 0xD000 0000 - 0xDFFF FFFF as last block.
