Delta-sigma modulation generates a single-bit output, where it achieves higher conversion efficiency by transmitting only the changes (delta) in value between consecutive samples, rather than the actual samples themselves.
It achieves high resolution by greatly oversampling the signal (much higher than the minimum Nyquist frequency of twice the highest signal frequency), and then using a digital (decimating) filter to generate a conventional multi-bit, lower frequency digital output of the signal.
