primetime powertrace
vt05
Newbie
Newbie level 2
I extracted a power report from primetime, but I want to extact also a powertrace report. Could someone knows the command for powertrace extraction?
You can specify the time range for which you want to report the power trace:
report_powertrace -start_time <start_time> -end_time <end_time> -file <filename>.txt
Thank you for your reply. Is it needed to place also a command to enable this option? (something like set_power analysis options ... )?
LaTeX Commands Quick-Menu:
