grizedale
Advanced Member level 3
In Half-Bridge SMPS, the peak primary current is, generally speaking, the same height as in continuous mode flyback......this is because with Half-Brdige SMPS's, the primary coil only gets half of Vin switched across it, due to the rail-splitting capacitors.
So why do we say that the Half-Bridge SMPS is better than flyback SMPS from an EMC point of view?
