Price of a PCB thats 2mm thick?
T
treez
Newbie level 1
Hello,
We wish to get PCBs manufactured which are simple, double sided, but 2mm thick...as you know, PCBs are usually 1.6mm thick......do you think the 2mm thick FR4 PCB will be much more expensive.
Please answere for
1...FR4 type
2...CEM type
There should be no big difference for volume production, at minimum making full panels, e.g. + 5%. CEM is restricted by available substrates.
Reactions: treez
    T
Manufacturers have different calculation for prototypes, you should check several vendors. I'm generally quite satisfied with multi-cb.
Reactions: treez
    T
