Vadosssss
Newbie
Hey. I am new to VHDL programming topic. Faced with an overwhelming task. Objective: to simulate a noise generator for a signal. I have searched and read a lot of articles and posts on the forum. Found the following code. The problem is that when I execute it, I get the result shown in the screenshot below. Can you help me get it up and running correctly? The author of the post has a screenshot where the code is working correctly. But communication with him has been lost.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL; --try to use this library as much as possible.
entity sine_wave is
generic ( width : integer := 4 );
port (clk :in std_logic;
random_num : out std_logic_vector (width-1 downto 0);
data_out : out STD_LOGIC_VECTOR(7 downto 0)
end sine_wave;
architecture Behavioral of sine_wave is
signal data_out1,rand_temp1,noisy_signal : integer;
signal noisy_signal1 : STD_LOGIC_VECTOR(7 downto 0);
signal i : integer range 0 to 29:=0;
--type memory_type is array (0 to 29) of integer;
type memory_type is array (0 to 29) of std_logic_vector(7 downto 0);
--ROM for storing the sine values generated by MATLAB.
signal sine : memory_type :=("01001101","01011101","01101100","01111010","10000111","10010000","10010111","10011010","10011010","10010111","10010000","10000111","01111010","01101100","01011101","01001101",
"00111101","00101110","00100000","00010011","00001010","00000011","00000000","00000000","00000011","00001010","00010011","00100000","00101110","00111101");
--hi
begin
process(clk)
variable rand_temp : std_logic_vector(width-1 downto 0):=(width-1 => '1',others => '0');
variable temp : std_logic := '0';
begin
--to check the rising edge of the clock signal
if(rising_edge(clk)) then
temp := rand_temp(width-1) xor rand_temp(width-2);
rand_temp(width-1 downto 1) := rand_temp(width-2 downto 0);
rand_temp(0) := temp;
--data_out <= sine(i);
i <= i+ 1;
if(i = 29) then
i <= 0;
end if;
end if;
data_out1<=to_integer(unsigned(sine(i)));
random_num <= rand_temp;
rand_temp1<=to_integer(unsigned(rand_temp));
noisy_signal<=data_out1+rand_temp1;
noisy_signal1<= std_logic_vector(to_signed(noisy_signal,8));
end process;
end Behavioral;
