Preparing Layout for QFN Package
raed_microwave
Full Member level 1
Kassel, Germany, Germany
Hi
Recently I have bought Hittite switch (HMC547LP3) and it is in QFN package and I know from data sheet that there some pins for ground connection and there is exposed ground paddle in the center of package. I'd like to know , is it possible to connect the pins for grounding to the exposed ground paddle in the layout or I have to put a ground for each pin ?, Actually this is first time for me to draw like this layout, therefore I need your help to draw the grounds in the layout of this package.
I have attached the outline drawing of switch.
Thanks in advance
raed_microwave said:
Hi
Thanks in advance
Yes it is ok to only have one ground shorting the QFN pins and the paddle. The reason for that is to connect the ground pad on the middle or heat pad to the largest copper area on the board which is the ground so that the heat will scatter and dissipate quickly. hope this helps.
do you want to know how you can do it?
Hi Zula
I do not understand you.:)
