Amr Wael
Member level 5
Hello,
I am looking for a precision opamp with a high gain bandwidth product above 200MHz that can tolerate high common mode voltages , +/- 20V
I have seen a lot of ICs for different manufacturers , analog devices , TI,ST etc but all the ICs I find either have very low voltage supply which results in low common mode voltage or their GPW is less than my requirement. Do you have any recommended ICs or do you have a solution for decreasing the common mode voltage without attenuating the differential input?
Thank you very much in Advance!
