circuitking
Full Member level 5
Hi
In LVDS output swing in the transmitter is -350 mV to 350 mV. After doing the pre-emphasis, is the swing going to be increased (Vpp in the image below)?. As per the image below it seems to me that the maximum limits are not going to change. What happens to the signal content marked Vs?. its swing is going be smaller than -350 mV to 350 mV, doesn't it degrade the signal quality at the receiver?.
From: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/wp/wp_pre-emphasis.pdf
Edit:
In the document it says
"It is necessary to select the optimum settings for both pre-emphasis and equalization. Over compensation can cause additional issues within the system. It will add extra jitter which will close the eye making it impossible for the receiver to interpret the information".
How do we know how much is over compensation, do we just have to look at the eye diagram at the receiver/transmission and decide or is there any rule of thumb?
Edit:
