Pragma attributes for WinAVR
se06745
Junior Member level 3
winavr pragma
Does anyone know pragma's definitions for WinAVR gcc compiler??
I need to controll memory areas where the compiler can access, and I know that with #pragma I can to define to copiler this area, but I don't know the parámeter.
Thanks for all.
Best Regards
winavr pragmas
Thanks!!! I'll try!!!
Added after 10 minutes:
I haven't find noothiing about the word ".sections"
Where do you see that?
Thanks!!
winavr attribute
Thanks I've seen it!!!!
The only problem is I need to change the linker parameters to move memory sections. I thought that was possible to create a new memory section (defined by me) and put it in a specific memory location in run-time (inside C code)
The only solution that I found is create my dinamic variables with mallocs (are saved in HEAP section) and modify in linker options the location of HEAP in external SRAM.
Best Regards!
