matcia
Newbie
I am designing a circuit that needs to use an RF active switch, which requires a DC bias to work. I have seen from the manufacturer's designs that they are connecting the traces with the DC bias with an SMA adapter; is there a specific converter that can be used to convert from banana plugs to SMA or is there a better way to connect a DC power supply to the PCB?
Thank you.
Thank you.
