[SOLVED] PPM signal from 8051 to control DC motor
Js_Ong
Member level 4
Member level 4
I have a DC motor come with a driver attached which say can accept PPM signal. How can I write a signal pulse to trigger the motor? Reverse 0.6ms, Stop 1.5ms, Foward 2.4ms. And the data sheet say the motor will run at the last speed even the PPM signal has been disconnected. I had write a normal pulse with above timing using 8051 but the motor is not running as expected. What was wrong about the PPM signal?
As it seems looking to your time stamps, a 0.3ms time base is common for all the operations. You can use timer to create signals only if you are clocking your 8051 in high speed. Use a round up value crystals like 12MHz. Or you can use simple counting loops to waste time and create delay of 0.3ms. Call the delay 2 times for reverse, 5 times for stop and 8 times for forward. Try to hold your pulse for around 50 to 100us before pulling it down.
It would be helpful if you can attach any link to the datasheet and paste your code here.
Pls look fr Robokit website the motor model RMCS 2104. That is the only info I hv to use the PPM in controlling the motor. Why different time of pulse given fr different control?
Different time of pulse are like a 'time stamp' and the receiver end already knows what to do when such specific kind of pulses are received. Any other pulses not recognized by the receiver will be ignored.
Can you attach your code here??
Hi Genovator,
Below my code in assembly. One pulse given. Please leet me know what's wrong?
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
ORG 0000H
                MOV TMOD,#10H   ;TIMER 1, MODE 1 16 BITS
                MOV A,0
                MOV P1, A
                MOV A, #0FFH
                MOV P2, A
START:  JB P2.0, FORWARD
                JB P2.1, STOP
                JMP START
STOP:   CLR P1.0
                MOV R0,#99H     ;1.5ms
                MOV R1,#0FAH
                CALL TIMER
                JMP START
FORWARD:        CLR P1.0
                MOV R0,#5CH     ;2.4ms
                MOV R1,#0F7H
                CALL TIMER
                JMP START
TIMER:  MOV TL1,R0
                MOV TH1,R1
                SETB TR1
                JNB TF1,$
                CLR TR1
                CLR TF1
                CPL P1.0
                RET
You haven't mentioned your clock speed, but by your code it seems you are driving a ppm signal with 2.4ms for both mark time and space time. And your output signal is of perfect 50% duty cycle. Your resultant frequency is 4.8ms, not 2.4ms. Are you sure this kind of signalling is required?
PPM is generally of two types: Positive modulated and negative modulated. See here.
In most devices, +ve PPM is used. I think you should try it once.
Advises: Ports and their respective bits are direct addressable. So you can write 'MOV P0, 0H' insteade of using accumulator.
Don't use P1.0 and P1.1 if they don't have internal pull-ups like 89c2051.
Hi Genovator,
I am using crystal 11.0898MHz with 89S52. The motor datasheet as below link. See page 2 about the pulse width. I do not know that I need to divide into 2 for the timing. And how do I know that the PPM used in this motor is positive or negative edge?
http://robokitsworld.com/documentation/Cur_Driver.pdf
When creating time delays, its better to use round-up value crystals such as 6MHz, 8MHz or 12MHz.
Try to find a 12MHz crystal.
I have seen that datasheet. well, it isn't actually a datasheet. More like a product brochure. They didn't shared much of the technical infos. Rather, they want us to rely on PPM receiver modules. They mentioned that the motor can be controlled by any PPM RC receiver. So a google search reveals RC receivers works with +ve PPM modulation. Assuming it is going to work on that, try this code...
ORG 00H
JMP START
ORG 30H
START:
JNB P2.0, FORWARD
JNB P2.1, STOP
JMP START
STOP:
CLR P1.0
CALL DELAY
SETB P1.0
CALL DELAY
CLR P1.0
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
JMP START
FORWARD:
CLR P1.0
CALL DELAY
SETB P1.0
CALL DELAY
CLR P1.0
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
JMP START
DELAY:
MOV R0, #16H
LOOP:
DJNZ R0, LOOP
RET
END
Reason behind using long list of DELAYs is just to check if this signalling pattern works. You can change it with timer if you wish. If it doesn't work, try replacing 'JB' with 'JNB'. I don't know why my simulator got confused between 'JB' and 'JNB'.
Reactions: Js_Ong
    Js_Ong
Hi Genovator,
Thanks for the advice. I had re- programme the code, and now it works. WIth the timing specified, ON OFF ON OFF.
I will post another problem that I am facing now.
