edaboardman
Junior Member level 3
latium design rules exist
A PCB routing has completed 100% in Blazeroutor,
then I pour the plane of the PCB in PowerPCB's Pour manager,
In Verify Design,chech connectibity got a "NO ERROR" result,
then execute File->CAM, error occors:
Clearence checking has been done for the entire design
**NO ERRORS FOUND**
Latium design rules exist,
Run Latium design verification from Tools, Verify Design...
connectivity checking has been done
Number of errors found -- 1
because there is nor position neither other detailed information,
I had to open Verify Design, which show me following information:
connectivity error :
(1031.84 1296.14 L3) subnet #1 of VCCINT
explanation:
Hatch outline(1031.84 1296.14 L3)
but I use "View Report",there is no error.
I check the position carefullly, nothing wrong. I justify the via fanouting to VCCINT,in edge of the plane, the error keep exist, but the position seems floating random.
why?
There are 2 VCCINT plane,which are connected by trace of other layer. is this the reason? I can try combine them to a plane,but how to explain this phenomenon?
**NO ERRORS FOUND**
explanation:
why?
