powering sequence of ADN2850
ctyszkiewicz
Newbie level 1
Newbie level 1
Hello
I am going to replace a resistor with a digital resistor ADN2850. The resistor is connected in series with a reverse biased photodiode (PD). In a data sheet for the ADN2850 I have read that a powering sequence is required (Rev. E | page. 15). Namely VDD must be powered before applying any voltage to Terminal B or Terminal W. In my design, power supply is applied to a cathode of the PD. One end of the resistor is connected to anode of the PD, the second end is grounded. Do I have to delay powering on the PD taking assumption that on powering a photocurrent is close to zero - the PD is not exposed to light?
Best regards
Cuma
if you are sure that , at all conditions , the PD current is zero on power up , then the power sequencing can be safely ignored.
