Powering battery charger module
Gaber Mohamed Boraey
Full Member level 5
Full Member level 5
Hello
I have that charger ,
which is Bosch brand , now it’s broke,
and I need make replacement circuit do same function
The battery are 3 li-ion in series with 1.8 ah, I think
I’ve found that module , please look at the link
This module take different input voltage, and provide up to 5 ampere, I will use charging current for about 450 ma, which is 25% the battery capacity , maybe less
And the charging voltage I will set to 12.6 v , which is 4.2 v *3 ,
My question, powering this module with this adapter enough?
Regards
Your link is a step-down buck converter. If you power it with 9V, you cannot expect 12.6 V output. Even though 'wall-wart' adapters are notoriously inaccurate, you're still taking a chance.
Isn’t it power input equal power output?
For 450ma and 12.6v the power is 5.67 watt
And for 9v and 2A the power is 18 watt
so much more than the power to be taken from the module,
How you think?
Internally your original charger had/has its power supply able to provide sufficient voltage so it could go up to 10.8 V (according to your photograph). Even that level is below your expected maximum 12.6 V.
On that basis you cannot charge three 4 V Li-ion cells in series. You'll need to try something different, like installing a higher voltage adapter than 9V. Or you can charge fewer cells in series. Or you can charge cells individually.
Or if you have 3 cells connected permanently in a pack, then any charging method needs to avoid abusing them.
An important point: Li-ion type are reported in the news as causing explosions and fires. You need to learn about battery management systems (BMS), and whether Bosch installed such smart circuitry in your charger, or whether it's inside each cell.
Like how much voltage?
Maybe you plan to build your own charger, rather than use parts from the Bosch unit? It's okay to home-brew your own, although you can expect to spend several evenings making adjustments of charge rate, final voltage, etc. You need the correct connector to hook up the battery pack.
To answer your question about power supply, it needs 3 or 4 volts cushion above the output of the buck converter. This assumes the units are genuine and available. Did you notice one link states 'out of stock'?
Okay, and how about ampere considerations if I need about 500ma at output?
Although it's easy to say the power source should provide 500mA, there's more to consider for the fact a battery is present. Its changing voltage affects everything. Its voltage opposes voltage from the charger. As the battery charges its voltage changes over time. And its ability to store electricity in the form of electrochemical energy changes.
The net effect can be calculated on paper... However the reality is you can't be sure what is the overall schedule of battery voltage versus charging current over time.
This is where you must plan to spend several evenings experimenting. Does a battery draw too much charging current at any time? Enough to be hazardous? Should you install a resistor in the current path? What ohm value? A transistor? 500mA is sufficient to make a small cell hot. You really ought to position a thermistor touching every Li-ion cell, to tell you whether a cell is or isn't hazardous.
These replies are coming from a distance, and I can't design an ideal charger for your battery pack.
Here is Bosch battery pack , take a look and let me know if add anything to you
Btw. I don’t design charger, the module is already designed as charger, i only need to power it right not to load on the power supply neither on the module and the battery to be safe
Take a look
I have no hands-on experience with charging Li-ion type. Usual advice says use the charger that came with your device. Notice your battery pack has several cautionary symbols.
The small types I've recharged are nicad and Nimh. They're designed to be tolerant of consumer use and abuse.
Battery life is limited no matter what type. After a few years my cell phone (with Li-ion battery pack) did not hold a charge, it operated less time as it aged. Your batteries should be tested individually for their condition. I wish I could help you more.
Okay thanks for your care to answer and try to help
I will try the way I’ve told you and will see
I hope if any other engineer see our discussion and can say something to help or have better ideas or experts
IIf you are sure that your lithium battery pack is 3S1P 11.1V 1800mAh, why don't you just use a 12.6V 0.3A -0.9A lithium battery charger to charge it directly? Why do you have to use a constant voltage power supply to power the DC to DC charger, and then charge it with this DC to DC charger?
I can suggesy you a 12.6V0.5A lithium battery charger:
LaTeX Commands Quick-Menu:
