Power via Ribbon Cable
~MJS
Junior Member level 2
Hello All,
I am considering powering the gate drive circuit for my H-bridge via a ribbon cable. Has anyone been successful doing this before?
My design is a full-bridge converter, with an H-Bridge on each side. Each H-bridge is being laid out on its own PCB so that I can disconnect one of the H-bridges, and connect a rectifier or other such topologies.
I wanted to use the ribbon cable to combine the gate drive power with the digital signals. The gate drive consumes about 1 Amp, so I thought I could use 10 wires (5 V_15 and 5 GND), and use the remaining part for my I/O.
So, how bad of an idea is this?
Thanks
If seen this quite often with gate driver circuits, and also used it in own designs. Power supply shouldn't be a problem, but common mode
interferences with single ended control signals possibly are. Do you have optical isolated gate drivers or power/logic ground tied to the
DC bus?
DC bus?
I do have optically isolated gate drivers, however, the emitters are not tied to the 15V bus. I have a seperate 3.3V bus so that my I/O can interface with a TMS320F2812.
Both the 15V and 3.3V are electrically isolated by means of V-Infinity VBSD1-SIP switching power supplies.
