Burner1
Newbie level 5
I am working with an LM628 Motion controller using it to read the position of an Encoder.
Let me preface by saying that I am a hobbyist and not formally educated in electronics. I understand a lot but sometimes miss the obvious.
I have set up the circuit with an Arduino and have it working with a larger power supply. I made the circuit around an pic 18f2520 and a 2.1a 5v regulator but the regulator is getting warm...and I don't think it should be getting warm meaning I need to go over my circuit.....but...I have a question I should be able to answer and I can not figure it out.
I am trying to reed the datasheet for the LM628 and I cannot figure out what tells me how much power I can expect it to use. This is my weakness in reading and understanding the datasheet.
Under "Absolute Maximum Ratings" I see maximum power dissipation of 605 mW. Is this the figure I need? Does this mean that at 5 volts I need a supply of 121 mA?
Thanks
Gary
Thanks
Gary
