power transistor in 6 GHz
khouly
Advanced Member level 5
EGYPT
i need to design 6 GHz Power amplifier using discreete transistor
is there any transistor can provide about 30 ro 40 dBm in this range
thanks in advance
khouly
The main suppliers of discrete transistors in this frequency range are: Filtronic ( for example LP3000p100 is a 33dbm Phemt), MA/COM,Eudyna,...
Anyway I would suggest that you use an internally matched module which reduces the cost of pripherals and test and troubleshooting by regarding the fact that its price is about 2 times a simple transistor.
    khouly
i am designing this for my master , so i must do everything :)
so i prfer to use a transistor , and i will design the all amp
thanks for the suppliers
khouly
FLC167WF (FUJITSU) is OK?
how much is your bandwith?
microwavehongjie
