mhamini
Member level 1
- Joined
- Aug 23, 2005
- Messages
- 40
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Iran-Tehran
- Activity points
- 1,690
I need to replace a power transformer in an old (1940) vintage tube radio. The schematic does not provide the A/C output voltage of the transformer but it does specify that the DC voltage after the filtering is 240 VDC and total current draw is 80.1ma. The circuit also uses the field coil (1060 ohms) for filtering which results in a 85 VDC drop. Is the correct transformer output voltage 325 volts? i.e. 325-0-325 for full wave rectification?
